hey.
i followed the guides that are available in the website. But i can't seem to get it. I need help on converting dat to avi.
first i used vcd gear to decode the dat file. I followed the instructions on the web. there were a few errors on the dat file. VCD gear said that it managed to fix it.
Then after i decoded the file, i open virtual dub. When i tried to load the file, this error came out.
MPEG: File ended unexpectedly during parsing - file may
be damaged or incomplete
does anyone know how to fix this? need help. thx
Two idea's
1. If i remember correctly, VirtualDub can open the *.DAT file directly.
2. If the *.DAT file is from SVCD then VirtualDub won't be able to open it even if you convert to MPEG file. You'll need to use VirtualDub MPEG-2.
I know, I know, but DAT files are not neccessarily MPEG-1. Remember the VCD Header trick? -
erm..
what vcd header trick?
do they have a program to check the mpegs is encoded under what sort of codec? -
Quickly,
Some DVD players don't like the SVCD format. If you use TMPGEnc to remux the source MPEG-2 you can make your SVCD appear as a VCD to the player.
The "Trick" has to do with making a VCD, not converting a VCD to another format?
MPEG is a standard, and they only come in MPEG-1, and MPEG-2. An MP3 for example is actually a MPEG-1 / Layer 3.
It doesn't work the same way as AVI if thats what your thinking. AVI is a container that contains an audio stream (usually compressed), and a video stream (usually compressed).
Video Compression - DivX, XviD, 3ivX, etc, etc.
Audio Compression - MP3, MP2, etc, etc.
MPEG is a container and a type of compression (to my knowledge)
Video is always MPEG-1 or MPEG-2
Audio is usually a flavor of MPEG but..........
I don't know if the *.VOB files you see on a DVD are a subset of the MPEG standard or their own format.
Video is MPEG-1 or MPEG-2
Audio is usually AC3, DTS, rarely MPEG.
to check for MPEG-1 or MPEG-2 you could try MPEGProperties:
https://www.videohelp.com/tools?tool=233#comments
(i hope i havn't screwed too much of this info up, i'm here seeking help myself)
Virtual dub
By santolina in forum Newbie / General discussionsReplies: 4Last Post: 22nd Jul 2009, 14:48 -
Virtual Dub problem
By rocka in forum EditingReplies: 3Last Post: 2nd Jan 2009, 04:46 -
I have a virtual dub question.
By mmmipa in forum AudioReplies: 6Last Post: 12th Mar 2008, 04:34 -
help with virtual dub
By Remyisme in forum Newbie / General discussionsReplies: 7Last Post: 30th Jan 2008, 16:36 -
Some questions regarding Virtual Dub
By smackyourfupa in forum DVD RippingReplies: 3Last Post: 5th Nov 2007, 07:00
