If anyone is having problems with audio staying in sync while converting to VCD/SVCD, you may want to give this a try. I had all but given up till I read this helpful tip from FOTD I believe.
1) Open up VirtualDub and load the avi file.
2) Select Audio\Full Processing Mode.
3) Select Audio\Conversion and set it to 44100Hz.
4) Select Save Wav and wait about 3-4 minutes.
5) Use that as the audio source in TMPGEnc.
Worked perfectly for every movie I've tried it on so far.
I'm sure some of you more experience users already know about this, but to any newbies like myself this will save weeks of aggravation.
Good Luck
Thanks for the tip on solving audio sync problems, but even after trying it I'm still having difficulty getting my audio to sync with my video.
I've tried changing the TMPGEnc template (PAL, NTSC), ripping first to a "wav," even using dbAmp Power Converter. No luck! Anyone with suggestions (a different program to do the conversion, that maybe I can tweak the frame rate with?) would be appreciated. Thanks! --Kaga. -
Dam, sorry man. Every movie I was having problems with worked perfectly after using that technique. Hope you find something that works.
definitive guide to audio/sync issues.
http://www.digital-digest.com/nickyguides/audio-synch.htm
My suggestions : always encode audio and video separately and remux with tmpegenc for mpeg and virtualdub for divx. If you have dificulty use Womble for mpeg - available in Spainand AVI Info for divx as suggested in the guide. Both allow you to offset the audio which will match sound to lips as long as you have same run length audio and video.
How to solve out of sync ?
By Benjy in forum Video ConversionReplies: 8Last Post: 14th Jun 2011, 06:54 -
The sound sync is off about 30 minutes into the movie
By Genetics in forum Newbie / General discussionsReplies: 5Last Post: 20th Jul 2009, 21:26 -
VCD to PSP - Audio out of sync in last five minutes
By BozQ in forum Video ConversionReplies: 6Last Post: 2nd Apr 2009, 22:43 -
video file out of sync after 20 minutes
By snafubaby in forum Newbie / General discussionsReplies: 1Last Post: 21st Feb 2009, 04:21 -
USING Nero TO SOLVE ALL BURNING PROBLEMS?
By guitarparth in forum Newbie / General discussionsReplies: 8Last Post: 16th Nov 2007, 18:18
