What's the quickest and easiest way to convert episodes from a DVD to MPGs that can be resized to the users requirements?
I've downloaded TMPGEnc DVD Author which is excellent at ripping the episode to an MPG, but the size is 800Mb, but I need it to be around the 90-120Mb mark.
Thanks all.
90-120mb - how long is the movie ? At that size, what sacrifices are you prepared to make ? To get it down to that range, you will have to
1. Heavily compress
2. Resize to a quarter the resolution
3. Consider chopping the frame rate
After all that, you might have something very jerky, blocky, indisinct and the size of a postage stamp, but the file size will be small. -
They're just 20 minute episodes of Futurama & The Simpsons.
I've downloaded epsiodes in the past and found 30-50Mb too poor, but anything over 90Mb has been pretty good. But it would be much quicker and easier (I hope) to rip them from my DVDs.
Quick easy way to convert DVD subs from 25fps to 23.976fps?
By nick1977 in forum SubtitleReplies: 19Last Post: 22nd Feb 2015, 18:36 -
Is There Really A Linux That's easy to use for Windows User?
By wulf109 in forum ComputerReplies: 60Last Post: 24th Mar 2012, 18:48 -
A quick, easy, and accurate way to test MKV files?
By guht in forum Newbie / General discussionsReplies: 2Last Post: 1st Dec 2010, 11:25 -
Easy/Fast MPG to DVD Options?
By beckmen in forum Video ConversionReplies: 5Last Post: 25th Feb 2010, 18:41 -
User-defined chapter points
By saber540ltd in forum SVCD2DVD & VOB2MPGReplies: 5Last Post: 26th Mar 2008, 19:38
