Is the saying pretty much true? If you have a movie with problems from the get go, lets say pixelization, is it going to come out with the same problem because thats how the original movie came downloaded?
Hope this question makes sense.
Results 1 to 10 of 10
I'm a victim of circumstance
Makes perfectly sense, and is perfectly true. You can't polish a turd is another way of putting it...
/Mats -
You could polish a turd, I just dont think the results would be worth it.Originally Posted by mats.hogberg
A movie with pixellation would indicate a movie that has already been converted to a compressed format. You may be able to help an old beat up VHS tape with some filters but if someone already jacked it up by not using enough bitrate or something... ....Originally Posted by tmgrood
Thanks,
I wont bother trying to polish the turd.
Waste of time that ive tried to do in the past. Not going to bother with it this time.I'm a victim of circumstance -
I have a slightly different view on it. Go read my post answer to the same question you posted on that other bbs
Cheers, Jim
My DVDLab Guides -
This is not an entirely true theory. Very often, I can make DVDs that look better than the source. But to what degree? That's always the question. Don't expect miracles, just expect something better.
Yeah, I posted in a couple different forums to try and find an answer.
Sounds like maybe I shouldnt give up so easily.
I may work with it and see what I can do. It can only drive me crazier. haha.
Thanks to everyone. Youze guyz are great.I'm a victim of circumstance -
Did you see my simple little example on that other board?
It (I think) shows a vast improvement over the original. You should see it in motion!Cheers, Jim
My DVDLab Guides -
Yes, I did see the pictures and the difference between the two.
Thats one of the reasons I think I will try to play with it and see
what I get.
Thanks.
Sometimes its tough being a newbie. hehe.I'm a victim of circumstance
