How do I convert either a wav or mp3 frame rate.
I can`t figure out how to convert it in besweet and when I try the wizard it always pops up a blank notepad before it will convert. What do I do with the notepad in the wizard?
I have converted my video from 23.976fps to 25fps and I need to do the same with the audio. If there is a better option than besweet can someone point me in the right direction?
Audio doesn't have a frame rate, it has a duration. If you have converted you avi to 25fps, then you need to shrink your audio to match the new length. Sound Forge or Audition can do this with little distortion. There are probably other apps that can as well.
How do you get wavworks to run? There are a lot of class files(never seen these before!) plus one .mf file.
I installed JRE so what now?? -
Did you read the instructions on the site? You shouldn't have a lot of .class files - you should have one .jar file. On my system, I can start it by doubleclicking on the .jar (just as the docs says), but WinZip and other unzippers often steal the .jar extension (just because it's in fact a ZIP archive) and starts unzipping it instead.
If so, you can start it from the command line with:
/MatsCode:java -jar WavWorks14.jar
Changing audio frame rate?
By architectofpain in forum AudioReplies: 22Last Post: 5th Apr 2013, 10:27 -
Audio sync issue, Virtualdub, old video clips changing frame rate
By litmus in forum Video ConversionReplies: 1Last Post: 19th Sep 2011, 11:35 -
Does changing frame rate make audio out of sync?
By aznbennet in forum AudioReplies: 2Last Post: 11th Sep 2011, 02:32 -
Change frame rate. Audio don't match with Video...?!
By SB4 in forum Video ConversionReplies: 2Last Post: 25th May 2011, 14:55 -
Avi lowering Frame rate and audio
By vipertongn in forum EditingReplies: 8Last Post: 14th May 2008, 03:31
