How do I check the frames per second on an asf file so I know how to convert an asf file to the correct MPG type using TMPG? Thanks.
in WMP hold the cursor over the sun icon in the bottom left corner while the movie is playing and itll show the KBPS/FPS. usually ASFs have shitty FPS (due to low KBPS, hence the lower quality) but if an ASF has a high KBPS (900+) it could look just as good as DivX or VCD/MPEG.
I don't see a sun icon. I'm using ver. 7 and I can't seem to find this icon. Is it in full mode or compact? Is it even in this version? Please help. Thanks.
sorry im using 6.4. WMP 7 Is a piece of shit, sorry to say but get rid of it. either in WMP7 (if u must use it) change the skin to Classic and youll see it in the bottom left hand. or startmenu->run->mplayer2.exe (this is the original WMP6.4 which is on ALL recent systems) and then do what i just described and itll show up. but do yourself a favor and get rid of 7, its a waste of space and resources, hogs massive amounts of both and has major conflicts with some CoDecs after its installed.
How can I convert ASF file?
By QuattroNN in forum Newbie / General discussionsReplies: 2Last Post: 29th Apr 2011, 13:11 -
.asf file will not open
By powrslave in forum Newbie / General discussionsReplies: 2Last Post: 25th Jan 2011, 10:56 -
Checking avi file corruption
By Igniss in forum Newbie / General discussionsReplies: 4Last Post: 11th Dec 2009, 09:43 -
How to convert a video of 120 Fps to... well 23.9fps or 25 fps or 30 fps
By Chuba753 in forum Newbie / General discussionsReplies: 7Last Post: 6th Jun 2008, 19:17 -
ASF file conversion
By sawm24 in forum Video ConversionReplies: 7Last Post: 11th Aug 2007, 08:47
