I have an external DVDRW drive, with Nero 5.5. When it try to burn a .mpg file, it tells me that Nero can only handle .vob files. How can I convert the mpg's to vob so that I can use Nero to burn a DVD movie?
Results 1 to 10 of 10
By reading the guides to your left (your other left <-------)
I read all of the dvd authoring guides on this site, and none explained how to import .mpg files into Nero for dvd burning purposes.
Originally Posted by nfl2k2
For NERO to burn DVDs, your MPG files must be authored to DVD files...with an authoring tool...(DVD-Lab, TMPGENC-DVD author, etc...)
NERO 5.x does not "author" -
It doesn't even burn that well, unless you use UDF mode.
how can I change the resolution without re-encoding?
/Mats -
You cant. You are attempting to burn a non compliant file onto a DVD. To do so will require reencoding to make it compliant, then authoring (usinf something else) to compile it into DVD format.
Your profile says you have an Apex dvd player. Why not burn the .mpg file in DVD-ROM (ISO) mode in Nero. Most low-end Apex players should play raw mpg files...no matter the resolution. Use a -/+ RW to test this. But I'd bet the Apex will handle it.
Originally Posted by Headbanger's Ball
Actually, the DVD is not for me, but some friends with various DVD players. I ended up re-encoding the out-of-spec files, and am currently burining the DVD+RW in my burner (56% done). Thanks for your help.
How to convert DV avi files to DVD ready MPG files with Win7 powershell.
By findus in forum User guidesReplies: 5Last Post: 19th Dec 2011, 16:42 -
How do I burn DVD ready .mpg files as a video DVD?
By sasuweh in forum Authoring (DVD)Replies: 3Last Post: 29th Nov 2011, 15:47 -
Can I burn a .mpg file to a DVD
By robrpb in forum Video ConversionReplies: 4Last Post: 8th Sep 2010, 20:56 -
Cannot burn an mpg on a DVD
By costaseco in forum Authoring (DVD)Replies: 2Last Post: 12th Nov 2009, 03:15 -
Burn mpg on DVD
By knowmyname_20 in forum Newbie / General discussionsReplies: 3Last Post: 27th Aug 2007, 19:31
