Hi im looking for something to record tv shows and video tapes onto my comp so i can make those into vcds.
i have a terrible comp so can someone please tell me what i should get. here are my comp specifcations
450 mghz and 60 megs ram ill prolly upgrade on ram sometime but right now i like my comp.
Please help
Where to start.... at that memory level I guess your running 95.
To do the job properly your CPU is okay to marginal mem should be 128 min desirable over 256k.
You'll need a minimum of 20 gig HD pref ata100 fast.
You can capture by an internal device either a pci card or even agp vid card with capture device or external USB device, I think most here would recommend internal device.
If you after TV shows then obviously the vid card should have a tuner although you could capture from external tuner.
The software to capture, manipulate and process for the most part can be found on this most excellent site.
I really think until you get your harware spec right you will be disapointed with your efforts.
DotCrawl filter on VHS Video shows blotches during play back.
By mlong30 in forum RestorationReplies: 31Last Post: 1st Feb 2012, 12:33 -
Capturing VHS using All In Wonder HD
By ukcolonelcolin in forum Capturing and VCRReplies: 14Last Post: 2nd Dec 2008, 10:32 -
VHS to DVD recording problem - strange line only shows up when viewed on PC
By CodySave in forum DVD & Blu-ray RecordersReplies: 11Last Post: 16th Jul 2007, 03:09 -
VHS cassette - when capturing to PC shows blue screens.
By 1gnition in forum Capturing and VCRReplies: 9Last Post: 23rd Jun 2007, 08:46 -
Baffled!! Titlewriter shows nothing but DVD Player shows Movie Name
By Subhash in forum Authoring (DVD)Replies: 16Last Post: 25th May 2007, 13:02
