I'm trying to figure out where I have a problem in analog (8mm) video capture. I have been told an external digital device (DAC, Canopus, etc.) with a firewire connection to the PC will bypass my video card. Is this true?
I'm asking because I get the same poor AVI capture results using either one. You can view the raw AVI capture and discussion at the following link:
https://www.videohelp.com/forum/viewtopic.php?p=939982#939982
Try StreamFab Downloader and download from Netflix, Amazon, Youtube! Or Try DVDFab and copy Blu-rays!
Results 1 to 9 of 9
Mick
yes, an external capture device like the canopus advc-100 will bypass the video card. when you use a firewire connection, it will transfer the video to the computer as a dv avi file. i just skimmed through your other post, but i bet you will get better quality with an external capture device.
MickB,
You said this was analog 8mm tape. Are you by chance using a Sony Digital8 camcorder to play those tapes back so you can capture them?
I didn't see the make/model of camcorder listed in your previous thread... -
Yes, by chance I'm using a Sony 8mm camcorder (about 4-5 years old) and rca cables connected to my AIW video card. However, it's not a digital, just analog. I have also connected my camcorder to a DAC external device with firewire with the same results. I also have used my much older camcorder with the same results (it's a Sony too).
I have given the same 8mm tape to a friend and he captured just fine using the same DAC device. I have just about given up on trying to capture.Mick -
Sitlet. Thanks but as you can see by the last post, an external capture device created the same degraded video capture. So if it's not the camcorder, the tape, external capture, or video card, what? About the only thing left is the motherboard or hard drives.
A friend is going to lend my his camcorder with an SVideo out and I will try that and see if there is any difference.Mick -
You've left me with only the faint hope it could be clogged video heads on your camcorder. I sure can't think of anything else...
Motherboard and hard drives aren't going to cause that effect. If they were too slow you would get dropped frames, but no this sort of extreme combing.
You said in your previous post that you friend had been able to capture cleanly on his system using your camera and tapes. What does he do differently to you ? Different hardware ? Software ? Cables ? -
This has been going on for a while so at this point I would "throw in the towel" as the saying goes and do the only thing left to do ... REFORMAT!
Drastic YES but it has been known to solve "oddball" issues like this.
REFORMAT and REINSTALL your windows operating system and then be sure to ONLY install the video/audio codecs you need for capture.
Oh and of course back-up all your shit first
guns1inger,
That's what is driving me nuts. He captures using the same programs as I have and using all the normal default settings. Perhaps FulciLives is correct, reformating. Thanks for trying.Mick
PS3, HDMI Splitter, Video Capture Device or Card, Ambilight, ADVICE!
By NexusSIX1976 in forum CapturingReplies: 5Last Post: 16th Oct 2011, 20:38 -
Need a recommendation on a new capture card/device
By MJDore in forum CapturingReplies: 1Last Post: 14th Oct 2011, 15:56 -
Video Capture Device: Cable length question (affects stalling?)
By iwc101 in forum CapturingReplies: 3Last Post: 18th Sep 2008, 01:09 -
Do I need a firewire card to capture video from my miniDV device?
By MPTESE in forum CapturingReplies: 8Last Post: 16th Mar 2008, 08:55 -
Question about software for K-World Video Capture Card
By cooper101 in forum Newbie / General discussionsReplies: 10Last Post: 31st Oct 2007, 13:49
