i just converted a 10min sample of a xsvcd 720x576 25fps pal svcd mpg2 to 352x240 29.97fps vcd ntsc std and im seeing alot of "jumps" in motion areas, probably because of the 25fps to 29.97fps pal - ntsc framerate conversion. is there a way to fix this, or would i just have to go down to 23.97fps? thx
<font size=-1>[ This Message was edited by: warbird on 2001-11-12 18:58:23 ]</font>
first..29.97fps=ntsc...25fps=pal....23.97=ntsc with 3:2 pulldown for playback
second..if your movie is 25 fps then encode it as pal.
My understanding and experience is that most dvd players will play all the frame rates. (encode it for what it is).if you need more help, then post again. -
Surfish is right you don't have to do pulldown if your fps 25.
I have pal movies and when I convrt to NTSC Idon't change fps at all just leave it at 25 it works
Frame rate conversion for NTSC to PAL conversion?
By Trellis in forum EditingReplies: 33Last Post: 27th Jul 2010, 10:55 -
NTSC video with a film-like/PAL to NTSC conversion type of look that shouldn't
By Bix in forum RestorationReplies: 34Last Post: 8th Feb 2010, 16:17 -
PAL to NTSC, NTSC to PAL framerate conversion?
By Baldrick in forum Video ConversionReplies: 44Last Post: 6th Dec 2009, 00:31 -
Problems with CMD-850 PAL to NTSC conversion
By vwy33 in forum Video ConversionReplies: 18Last Post: 31st Jul 2008, 08:55 -
NTSC to PAL, PAL to NTSC framerate conversion?
By Baldrick in forum Video ConversionReplies: 23Last Post: 23rd Apr 2008, 12:19
