  1. downloaded Screenblast Movie Studio but i have problem with it
    when i add .avi file to the media pool, it's ok, plays just fine
    but when i add it to the time line, and play it, the picture is very weird, something like colorized mess.....
    The avi's are compressed with huffyuv codec
    when i saved the avi's without any codecs, and tried again with movie studio, they were playing correctly
    so, i guess movie studio does not support huffyv codec?
    in the help is written that it may not support some kind of avi's
    I downloaded the trial of adobe premiere, and guess what, the same problem as with movie studio
    how is possible the leading products, to not supporf huffyv?
    what can i do? plug ins or what?
    i really need to get one of both producs to get playing these files correctly
  2. Fking, when you capture avi using huffyuv, make sure you have the "Always suggest RGB format for output" option checked on in the configuration. This will get make the avi appear normally in Premier and other editing software.
  3. aaaa.....
    why no one told me that before?
    i have already cutted and splited and converted using huffyuv without this check, 10s of files
    what if i reconvert the same files already ecnoded once with huffyuv, but this time with the check?
