What's this for? I forgot...
Results 1 to 13 of 13
Your miserable life is not worth the reversal of a Custer decision.
Any more information? Make, model?
There aren't that many cards that include a molex... -
Just provides that extra "kick", since most (all?) firewire devices are slf-powered (from the port).
You got me, but I have yet to see a (low-end) firewire card that doesn't have it. I'm paraphrasing from memory what the instructions specified.
Remember that your not only powering the FireWire card, but any device plugged into it.
No. Firewire operates (in some ways) the same as usb. It's not just for video anymore 8)
Oh yeah, the "any" part. Though "many" firewire devices don't need external (ie. AC) power, and get it straight from the source.
Fine!
Any FireWire device that needs power.
The iLink-type connection has only 4 pins and doesn't require power. (MiniDV cams)
They make a thing called FireWire Power Injector because some cards don't supply enough power.
http://fwdepot.com/thestore/product_info.php/products_id/372
http://fwdepot.com/thestore/product_info.php/products_id/652 -
IEEE1394 (Firewire) standard has option for supplying power to devices. It's 1.5A, voltage anything between 8-30V, which means it can supply lot power (ca. 12-45W vs. USB 2.5W).
However, not every PC is able to supply that much power via PCI-bus. But it's easy load for PSU, therefore normal PSU-connector. -
This is very true... used to work for a mfg that made digitizers for various I/O ports. Most of the time it was self powered off the port... but on occassion you'd find a port that didn't have enough power... subsequently a wall wart was supplied, but rarely needed.However, not every PC is able to supply that much power via PCI-bus. But it's easy load for PSU, therefore normal PSU-connector.
auxiliary power connector on aiw2006?
By greenbag in forum ComputerReplies: 8Last Post: 2nd Sep 2010, 18:37 -
What is this power connector ?
By Noahtuck in forum ComputerReplies: 3Last Post: 14th Jan 2010, 15:32 -
8400 gs 256 mb power connector issues
By hairysac in forum ComputerReplies: 4Last Post: 26th Apr 2008, 23:56 -
What is a pci-e supplemental power connector?
By yoda313 in forum ComputerReplies: 16Last Post: 30th Jan 2008, 19:30 -
PCI/PCI Express 1x usb 2.0 card with 2 internal usb inputs
By SIRCOOKS in forum ComputerReplies: 0Last Post: 24th Jun 2007, 12:58
