Hey can someone help me with this prob i'm having with my DVD player.
The problem is the damn DVD player won't play DVD's, it plays everthing else from vcd, cds etc, Everthing but it's primary function, playing DVDs. Is my player done for or can i be helped. The modle is a Samsung P231.
Has it just stopped working? If so, you may try cleaning the lens and see if that helps you.
Cobra -
Yes i did try cleaning the lens, however that was no help to me. As i said it would play VCD's & CD's, those type of things with no problem. When i try to play a DVD it tells me "no disc ". Can it be the DVD mode is not functioning? If so, is there some way i can correct this prob.
The prob 1st occured when i was watching a movie. I stoped it, when i wanted to continue watching the movie the play would not respond.
Samsung HT-C450/XEU & Samsung BD-C5300 hacks/codes needed
By raindancerob in forum DVD & Blu-ray PlayersReplies: 8Last Post: 5th Mar 2011, 11:45 -
Samsung VR350. Can't play DVD anywhereelse but in Samsung VR350
By gux70 in forum DVD & Blu-ray RecordersReplies: 4Last Post: 21st Aug 2010, 10:34 -
Samsung BD-P1590 VS Samsung BD-P1500?
By Darkerknight123 in forum DVD & Blu-ray PlayersReplies: 14Last Post: 3rd Jan 2010, 17:51 -
Samsung HT-Z210, Samsung HT-X250
By emmy207 in forum DVD & Blu-ray PlayersReplies: 2Last Post: 28th Mar 2009, 23:06 -
Stand Alone Samsung HD Tuner vs. Samsung DVD Burner/Tuner
By MacPCConsultants in forum DVB / IPTVReplies: 0Last Post: 7th Jun 2008, 02:42
