  1. PC keeps freezing when using TMPGE
    and when i scan for virus and also when downloading big files form internet,
    im using win98se
    i have 1.6 gig processor
    128 meg,
    as stated above my pc keeps freezing
    when using the above products,
    yet i can still acess the internet and download some files, not all
    after a while the pc frezzes and i have to reboot.
    i have scanned for a virus (no joy)
    i have used spypot (no joy)
    i have used adware (no joy)
    i have also used stinger (also no joy)
    i have a simler problem a few moths back with nero freezing
    however i went into msconfig
    unticked a few items in start up and everything was fine
    i cannot see what is wrong and what im sopposed to do next..
    do i need to format the harddrive?
  2. Check your CPU temp. Perhaps it's getting too hot. Encoders put more load on a processor (as you would imagine), and its temperature rises because of this.
    Are you overclocking? If so, cease, and see if that helps.
    If you're not overclocking and your CPU is too hot (say, above 60 C), then your heatsink/fan may need replacing.
