I have no idea where this go.
I have files for 3 VCD and I would like to add make one DVD out of them. I am not looking for anything fancy. I just want to put it in my DVD player and have it play the movie.
If you don't have it then download the trial version of TMPGEnc DVD Author and import your mpegs, TDA will convert the audio for you. If you need to extract the files from a VCD look here.
Well the file I have is 3 folders marked CD1 CD2 and CD3. In each folder are .r and random number after the .r( the seem somewhat sequntincal) All are 14.3mb exactally. This seems kinda odd.
The files with their sequential numbering should be fine if they are complete. I suggest you ask the person(s) you got them from how you should proceed from here.Originally Posted by bigcrav
My VCDs have files names "aviseq001.dat" "aviseq002.dat" etc (if memory serves me). I used isobuster to rip these back off the VCD to a MPG file. I then demux with tmpgenc and change the sampling rate of the audio to 48khz with ssrc. Then multiplex back together. As mentioned, TDA may work too, but I've never used it. I don't know anything about .r
DVD to VCD... HOW?
By aglara in forum DVD RippingReplies: 3Last Post: 16th Jun 2010, 23:29 -
VCD to DVD
By Argon in forum MacReplies: 4Last Post: 5th Oct 2008, 10:01 -
Will a DVD player play any files but DVD/VCD and CD audio?
By brassplyer in forum DVD & Blu-ray PlayersReplies: 3Last Post: 24th Sep 2008, 19:32 -
Problems with a VCD? A somwehat odd way of converting VCD to DVD
By dvd3500 in forum Video ConversionReplies: 2Last Post: 19th Oct 2007, 06:54 -
Convert NTSC AVI, DVD, (S)VCD to PAL DVD, (S)VCD
By scratchman in forum User guidesReplies: 14Last Post: 4th Jun 2007, 01:36
