What is the lowest rate of encoding MPEG-2 video where the degradation of quality is not noticable by the human eye? The video is fairly low motion (guitar instructional video)
Thanks,
Mike
How big a framesize? What are you viewing it on, how big a TV screen?
352x240 encoded half D1 (352x480) on a 19" TV, probably around 2k.Cheers, Jim
My DVDLab Guides -
Quality is a subjective thing and also depends on the amount of noise present in the source, the amount of action, and the intensity of panning. Those three things really eat up the bitrate. You state that there's not that much action. Is there a lot of panning or zooming in and out?
The action and panning are intuitive, but the noise is a big reason because the noisier your source, the more information your encoder is trying to digitize. This is especially true when transferring from tape. It'll try to faithfully reproduce everything, even noise. Nuff said about that.
Another factor is the length of recording. The shorter the video, the more flexibility you have in bitrate. If you absolutely, positively have to fit it on one DVD, then you will have to start compromising quality when your video duration passes 2 hours. I'm assuming you will be capturing full DVD resolution of 720 x 480 (or 576 PAL).
Bitrate Question
By x0pht in forum Video ConversionReplies: 5Last Post: 18th Jan 2011, 00:00 -
Question about bitrate, spikes and Bitrate viewer
By sasuweh in forum Authoring (DVD)Replies: 3Last Post: 25th Oct 2010, 16:01 -
Bitrate question and two pass question
By cyberlion in forum EditingReplies: 17Last Post: 11th Oct 2010, 12:17 -
Bitrate question
By eclipse95 in forum Video ConversionReplies: 7Last Post: 10th Nov 2009, 23:03 -
Bitrate question compiling a DVD
By dvdnewb2 in forum Video ConversionReplies: 6Last Post: 18th Aug 2008, 09:31
