Hi,
i have been making DVD's containing whole seasons of programs, either from avi sources or ripped from my standalone dvd recorder.
i make dvd compliant mpeg 1 files eg vcd with 48 khz audio and proper GOP limit.
the problem comes when i author the DVD, everything goes as normal untill i try to play either the mounted image on a virtual drive, or as an actual burned DVD.
The problem must be with the number of files in 1 track. ive made plenty with 3 or 4 files per track, no problem. but in doing these there can be upwards of 8 - 13 or more. which cause some to become unplayable eg just stalls after 1 sec in and wont play anymore. but it only happens in random chapters, say 5,8 and 12 but the rest all play fine.
the only solution is to put them in seperate tracks, which i dont want to do as it messes up the menus. or use the mpeg tools in tmpg enc to join them all into 1 file. this 1, 5 or 6 hour file plays fine.
anyone have any ideas.
Baz
Results 1 to 1 of 1
DSP - Track and Story Chapters exceed Limit
By Toxas in forum Authoring (DVD)Replies: 0Last Post: 24th Aug 2011, 03:46 -
TMPG DVD Author-old version
By Mållgan in forum Authoring (DVD)Replies: 12Last Post: 7th Mar 2010, 16:46 -
Does Tmpg Divx Author encode or it only author ?
By BlackShadow90 in forum Authoring (DVD)Replies: 3Last Post: 29th Jul 2008, 03:56 -
About the .srt subtle files and the TMPG DVD Author
By ihmcjacky in forum Authoring (DVD)Replies: 2Last Post: 10th Mar 2008, 10:58 -
tmpg dvd author 1.6 help plz
By nwa in forum Authoring (DVD)Replies: 8Last Post: 6th Jul 2007, 18:59
