I've just got an Akai DV-PX7000. Well it plays every format DivX or XviD I've tried so far.
But aspect ratio is wrong. Now I live in Europe in the region where PAL is the TV format.
It seems to me that the simple problem is that avi's are encoded for viewing on a PC screen, where the aspect ratio of the pixels are 1:1. But on a PAL TV the ratio is 54:59, that is every pixel is a bit weider than it is heigher. If the player doen't compensate for that, the picture looks stretched. And that's excatly what happens.
Does anybody know if this i a common problem or if it can be solved?
Dr. Fresh
That's part of the problem. But I think that small difference would hardly be noticable. The biggest issue is that there's no set standard for pixel aspect ratio in Divx/Xvid/Mpeg4 files. People do all kinds of crazy things.
My DVD player (Liteon LVD-2002) has separate zoom for the width and height so I can adjust the picture if the player picks the wrong aspect ratio. Most of the Divx players don't seem to support this though. -
Well that would certanly be a very good option to have. I can tell you that the 1:1 versus 54:59 difference indeed is notisable! I had the same problem when I used to convert to SVCD. I wasn't aware of the 54:59 ratio, and I allways thought that something were wrong with my files. But after I learned to compensate for that it all looked fine.
But as I have no stretching option on my player I'm not very happy with DivX/XviD playback anymore
Dr. Fresh
Aspect Ratio?: MKV -> XviD
By Randm in forum Newbie / General discussionsReplies: 9Last Post: 6th May 2009, 12:01 -
Xvid Playback Aspect Ratio Problem
By midders in forum Video ConversionReplies: 3Last Post: 1st Apr 2009, 15:24 -
Aspect ratio for stand-alone DivX/XviD players?
By Gew in forum RestorationReplies: 1Last Post: 9th Mar 2009, 14:52 -
Converting VOBs to xVid with 4:3 aspect ratio?
By AOBCD8663 in forum Video ConversionReplies: 2Last Post: 18th May 2008, 21:31 -
Changing aspect ratio on an xvid encode
By SupaDawg in forum EditingReplies: 1Last Post: 6th Jan 2008, 04:59
