  1. Does anyone know if this will be full D1 720 x 576 or will they go for Half D1 of 352 x 288 ? I only ask cause its on the news everynight but they still haven't mentioned what bit rate they'll be using. I think I heard they're definitely going for AC3 audio though.
    Buddha says that, while he may show you the way, only you can truly save yourself, proving once and for all that he's a lazy, fat bastard.
  2. Member flaninacupboard's Avatar
    Aug 2001
    Northants, England
    well i heard they're using a transport stream so it can be redirected at any time rather than a program stream.
    I also heard it's a weird GOP pattern, there'll be this really big really pretty looking I frame and everyone will rejoice, and then there'll just be crappy B frames for the next 5 years. then a P frame come along, with the promised of an I like in the past, but really it'll just be another five years of B until someone else get put in office and creates another I.
  3. Member flaninacupboard's Avatar
    Aug 2001
    Northants, England
    ah, some kind of NTSC hybrid? 352x480 at 25FPS?
