When i use DVDx and Panasonic Mpeg Encoder plugin or LSX Encoder plugin DVDx only encodes 2 frames....i set all the rite settings for DVDx and the plugins but this always happens..can any one of u guys help me and dont make suggestions on useing FlaskMpeg i dont hate it but i had bad experiances wit it....Please help me![]()
Results 1 to 11 of 11
Does it work without the plugins?
I do not use it with the plugins, and it works just fine.
I use a celeron 366 178mb ram win98.
good luck.
dp -
i dont want to use it by it self i want to use it with aplugin so i can egt better qaulity mpegs
I don't use DVDx but I'm curious to know what problems you had with Flask.
It's on of the most newbie friendly programs there is...
Regards.
Michael Tam
w: Morsels of Evidence -
the problems i had were that when i load the vobs it will take 5-10 mins to load and when change or opening the settings it is the same thing...and if u were going to suggest other versions i tried all the orignals and modfied versions....the only all-and-one software that works with me is DVDx
Well, that shouldn't happen (and doesn't happen)...
I hope you ripped your VOBs with DVD Decrypter or Smartripper on "File Mode".
Regards.
Michael Tam
vitualis i did rip the vobs with DVD Decrypter or Smartripper on "File Mode" and it happens FlaskMpeg isnt just made for me DVDx is the only one or are there other programs like DVDx ???
Well, I have no idea why you had the problems...
FlaskMPEG works well for most people who use it.
As for DVDx, I have no experience with it but most people see to be able to use it fine... Perhaps you should perservere with it a bit longer.
Furthermore, you don't have any other general stability problems with your PC do you? Sometimes a fresh reinstallation of Windows will cure all ills.
Regards.
Michael Tam
Every thing is fine.....no problems..i havent got a blue screen of death for the past 2 months...so i guess im doing okay
Need plugins
By IT learner in forum EditingReplies: 6Last Post: 12th Sep 2011, 09:49 -
Plugins for premiere
By IT learner in forum EditingReplies: 2Last Post: 11th Sep 2011, 15:29 -
VirtualDub Plugins
By gazza67 in forum Newbie / General discussionsReplies: 6Last Post: 12th Dec 2009, 08:50 -
vd plugins
By uglijimus in forum Video ConversionReplies: 3Last Post: 9th Oct 2009, 06:27 -
What plugins for Vegas Pro 8.1 can I get?
By ingeborgdot in forum EditingReplies: 6Last Post: 4th Oct 2008, 11:43
