Ok, Ive been encoding with TMPGEnc Plus and my anime always had cut off subtitles. After a LOT of tweeking and testing I found 420x446 was the best for 640x480 source rez. I have other animes and movies with different resolutions and I really dont want to go through all that again to correct overscan. Is there a calculater out there that calculates for overscan?
Results 1 to 19 of 19
FitCD
If your AVI is 640x480 and you are converting to DVD at 720x480 then your final resolution should be 720x480 but of course that doesn't take any account of TV overscan.
So try 688x464 inside of a window of 720x480 (in other wodrds 16 black on either side and 8 black on the top and bottom).
If that isn't enough to account for your overscan "issue" then try 656x448 inside a window of 720x480 (in other words 32 on either side and 16 on the top and bottom).
Sorry but I should have stated that I was making SVCD's and NOT DVD's. What is the formula for calculating ratio's?
If your MPEG-4 AVI is 640x480 and you are making a SVCD of it then try 448x448 with 16 pixels all around to make it 480x480
FitCD is easy to use once you "fool around" with it a bit.
Originally Posted by FulciLives
420x 446 looks better to me, 448x448 cuts off too much on the sides. Now what about wide screen movies on SVCD? Will I have to use a different ratio? -
Originally Posted by Pirate_King
edit - nevermind, i see you're making svcd's. -
Remember that if you had the original DVD discs they would look like your AVI resized from 640x480 to 480x480 with no account of overscan. The problem is most of these anime AVI files put the subs too low on the screen (don't know why they do this) so on a TV the subs get cut off. So you want to reduce the overscan enough so that you can easily see the subs but you really don't want to overdue it ... after all it is a normal thing (i.e., TV OVERSCAN). Don't think Japanese anime creators don't know this ... they do and account for it.
So yes the image extends off the visible part of the TV screen but they KNOW that and EXPECT that so they don't put anything crucial near the extreme edges of the image.
Originally Posted by dafreak
I see a picture preview but I don't know if you can actually preview the video. I kinda doubt that.
But I haven't played around with it enough to test all the new stuff in this most current version.
- John "FulciLives" Coleman
P.S.
If you need to crop do it with VirtualDub or GORDIAN KNOT where you get a LARGE image to work with. Once you figure out your crop values just plug them into FitCD"The eyes are the first thing that you have to destroy ... because they have seen too many bad things" - Lucio Fulci
420x446 hasnt thrown off the apsect ratio at all. Ive compared my TV's picture to my PC's and the TV's picture doesnt look squeezed at all. -
It might not be easy to tell with the naked eye but the aspect ratio is incorrect.
Math does not lie :P
So if 420x446 is the wrong "math" for apect ratio then is the correct math always say 444x444, 446x446, 448x448, etc........? By that logic my picture was squeezed then I guess, but IT LOOKED SO GOOD! -
If the AVI is 640x480 to start with then the best SVCD resolution to use is 448x448 as this accounts for overscan without "wrecking" your aspect ratio.
VOB2MPG Correcting PTS values
By dvdmovie in forum SVCD2DVD & VOB2MPGReplies: 3Last Post: 15th Mar 2012, 15:06 -
Correcting colours in CS4
By sterankin in forum EditingReplies: 2Last Post: 6th Sep 2011, 05:24 -
Correcting MP3 song name or artist name
By jackdup in forum AudioReplies: 6Last Post: 2nd Oct 2010, 17:09 -
Correcting a Subject Line?
By solarblast in forum Newbie / General discussionsReplies: 1Last Post: 13th Dec 2008, 09:14 -
Correcting VLC 5.1 Playback problem
By Millwood in forum MacReplies: 2Last Post: 15th Mar 2008, 09:12
