  1. Hi there,
    I am following the dvd encoding guide on doom9.org to convert a DVD to mpeg2 usin Cinema Craft Encoder. When I start the encoding process, CCE only encodes up to a filesize of 80MB and then just stops!! I am doing 2 pass VBR at 3000kbs. All other settings are the same as the guide.
    Thx
    Apr 2004
    Miskatonic U
    Did you enter a serial number when you installed ? If not, you are limited to 3 seconds of encoded video.
  3. Yes I did.
    Do not know what is up.
