Ok, here is the problem:
I have a capture card and i have used PowerVCR II for a couple of months but a couple weeks ago it stopped working and when i try to turn it on i get this error window. it is titled Microsoft Visual C++ Runtime Library and the text inside it says Runtime Error! Program: [dir] abnormal program termination and all i can do is click OK and the program will close.
I have had this problem before, the solution was to format the hard drive and install windows again. Now that i dont have cable, i can't do that because of the amount of windows updates i will need to do after i install windows. I have tried downloading some new libraries from Microsoft's website, but they did nothing. I found a thread about this on this forum system but it didn't help me at all. Can you guys think of anything i can do to fix this? Right now i just have a dualboot set up and i go into the other installation to capture if i need to, but that is a real hastle when I am in a hurry.
Google the MS error and find the fix. Check the MS KB.
Runtime error
By alintatoc in forum ComputerReplies: 0Last Post: 20th Dec 2010, 15:19 -
Runtime error
By The Monarch in forum ComputerReplies: 4Last Post: 28th Feb 2010, 03:42 -
runtime error
By ram16 in forum Newbie / General discussionsReplies: 9Last Post: 20th Dec 2008, 23:04 -
Runtime error
By Illusionist in forum ComputerReplies: 7Last Post: 13th Jul 2008, 00:01 -
Runtime Error
By clivedavies328 in forum SVCD2DVD & VOB2MPGReplies: 3Last Post: 17th Jul 2007, 15:33
