So I got this uber high resolution (1920x1080) .ts file from newsgroups its 9gb for one movie. VLC can play the file fine. But I want to convert it to something a bit more space friendly to store on my server. I know the video in the .ts file is some sort of mpeg2 and im pretty sure the audio is ac3, but I cant find any progs that can convert it. VDub parses the file fine, but when it gets done, it just displays a bunch of green nonesense. I demuxed the audio from the .ts and thats it. DVD2AVI crashes when it starts converting the movie no matter what settings/codec I use.
help?
Results 1 to 23 of 23
ts files are transport mpg streams.
try renaming the file to mpg and then convert to whatever format you'd like. not sure if it will work but you can give it a try. -
Why don't you ask the newsgroup where you got this file from?
PVAStrumento crashes as well
Time's not wasted when you're wasted all the time. -
take a look at the forums at www.doom9.org I know they are starting to get into the dvb discussions. Might help
-Suntan -
Originally Posted by pyrohydraTime's not wasted when you're wasted all the time.
any other suggestions as to what to do?
try projectx instead of pvastrumento
possibly the modified version of dvd2avi available here:
http://www.patjames.com/hdtvtowmv.htm
... just suggestions..."speed's just a question of money. How fast can you go?" - Mad Max, 1979 -
Originally Posted by twodogsTime's not wasted when you're wasted all the time.
Originally Posted by legoman666
But your problem is gunna be that the quality (bitrate) of your movie is way above DVD spec, normal SD TV is roughly mid DVD spec. (6000 - 7000kb/s) So even when you demux it successfully, your going to have to re-encode it. -
dont do things the hard way ..
bbtools demux or ][muxer (moonlight cordless) or manzinita will demux the streams easy enough ..
there might be more than 1 stream but unlikly , but if there is , pick the ones you want.
you will have a m2v file and a ac3 file (though transport streams will take different types of audio files than just ac3)
now you want to ruin the picture and make it smaller ?
why did you download the HD file then ?
you will have to resize it and re-encode to a different mpeg profile ..
if you want to keep quality and make smaller - encode it to a wmv9-HD file ...."Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
Originally Posted by BJ_M
anyay, ill try out those progs you referred. thanks.Time's not wasted when you're wasted all the time. -
you can also drop a ts file into both mainconcept and into procoder and they will convert it just fine, you might be able to use tmpegenc also
procoder will even let you chose which streams to use and will read and convert the ac3 file"Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
][muxer demuxed the files fine, but the only prog that i had that would read (not play, WMP crashed trying to play it, VLC still played it fine) was vdubmod. I tried load up the plain mpg file into tmpgenc, but it couldnt read it, so I set up vdubmod to frameserv and its converting it right now to something more usable. Hopefully flaskmpg will be able to convert the mpg to a nice avi file for my server that doesnt take up 9gb O.o
thanks for all the help people.Time's not wasted when you're wasted all the time. -
windvd and media player classic will play those HD m2v files
powerdvd will often crash or not play them at all ..
v-dubmod, as you mentioned also playes them fine"Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
you could have de-muxed the ac3 in ][muxer and muxed the ac3 w/ the avi in v-dubmod saving yourself a few steps
v-dubmod doesnt have to open ac3 files to mux them ...
just use the "streams" selection and add the ac3 file"Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
really? didnt know that, that wouldve saved me a lot of trouble earlier...
Converting a 4:3 project for a 16x9 HDTV
By jeffgrooves in forum Video ConversionReplies: 2Last Post: 24th Aug 2010, 13:25 -
Converting .ts/avc HDTV files to .avi
By Kull in forum Video ConversionReplies: 2Last Post: 8th Feb 2010, 19:57 -
Capturing HDTV and Converting/Exporting
By eighteesix in forum Capturing and VCRReplies: 1Last Post: 26th Mar 2009, 02:20 -
Converting TS Files with HDTV Content
By AlexTimaios in forum ffmpegX general discussionReplies: 2Last Post: 19th Aug 2008, 01:56 -
Problems with connection with my Panasonic HDTV and Timewaner HDTV box...
By S4one in forum DVB / IPTVReplies: 7Last Post: 2nd Nov 2007, 22:39
