vfapiconv accepts dvd2avi d2v files directly ...
procoder works with these files - no problems
i just tried it - to make sure
though procoder 2 also will accept vob files and load them all automatically .. and accepts ac3 and dts audio also
Results 31 to 37 of 37
Thanks BJ, actually although Procoder recognizes the VFAPI file, it accuses an "error" when loading;Originally Posted by BJ_M
I've realized that, after installing DGMPGDec, it messed up DVD2AVI and the D2V files created by DVD2AVI became corrupted;
As far as I've read, it'd be better to quit DVD2AVI and use only the other new one
Anyway, the D2V file it created + VFAPI was recognized by Procoder, but it returned an error
Well, I'd like something really simple, frameserving is OK, but using two programs for that doesn't sound cool
I think I'll stick to DVD2AVI plus TMPGEnc anyway;
But I admitt I am very annoyed by Maestro error, I cant understnad why it accepts a WAVE file and doesn't accept two AC3 224 kbps files
Really annoying, it's a shame cause I only know to use it, don't have time now to learn other tools and of course it's very powerful;
Thanks,
Zetti -
Hi all again,
It's a shame to inform you that, even after re-encoding at low bitrate, Maestro refused to author it accusing high bitrate (more than 10.8; whih is an absurd);
It has problems with the different audio streams;
Well, I'll trhink I'll look at another sw soon;
Thanks to all,
Zetti -
it might be your version also .. i never had this problem
Freestyler, I tried with one PCM stream and it worked, I'm sure at this point it's not actually a problem with high bitrate;
BJ, my version is 2.915a;
Well, I feel bothered, likely to give up
Thanks to all that replied;
Zetti
Should i put average bitrate or max bitrate in 2pass encoding mode?
By tendra in forum Video ConversionReplies: 28Last Post: 11th Nov 2011, 07:38 -
What is max bitrate and max channels supported by PCM audio format?
By Bonie81 in forum Newbie / General discussionsReplies: 10Last Post: 18th May 2010, 23:35 -
Using mutiple passes with lower bitrate vs single pass with high bitrate on
By jones24 in forum Newbie / General discussionsReplies: 15Last Post: 14th Aug 2009, 18:17 -
Most compatible codec, Lossless bitrate, and max bitrate
By sevenlayercookie in forum Video ConversionReplies: 2Last Post: 6th May 2009, 20:43 -
Low bitrate source to High bitrate target
By sameerdhiman in forum Newbie / General discussionsReplies: 2Last Post: 7th Nov 2008, 23:54
