I just purchased the beverly hills cops dvds, without cases, and I was wondering how I make a case insert that has a picture spread over a few dvd spines?? Like I have seen some dvd sets that when put together, make a full picture from the spine labels... How do I do that?
Originally Posted by untouchableflowz
I imagine you would use Photoshop or Paint Shop Pro to cut the image into little long rectangles, then go from there. Print each one and cut it out, or if you have something else you wanna do, just keep in mind that you want those little rectangles on the spines. GOOD LUCK! -
Try this here website:
http://www.dvdcoverart.com/
Print on legal size paper 8 1/2 x 14 otherwise it won't fit on a normal sized piece of paper 8 1/2 x 11 and most likely your printer will scale the image down a bit so it will end up too small.
I burn mine onto a CD and take it to Kinko's and then print there from their computer to a color Laser Printer ... again legal size paper.
Sometimes you can even give them the CD and tell them what files to print and they will do it for you.
Avatar Collectors Edition Audio Options
By Chudz in forum AudioReplies: 0Last Post: 5th Jan 2012, 06:45 -
Dvd player not playing box sets
By kurzsy in forum Newbie / General discussionsReplies: 1Last Post: 15th Feb 2011, 10:16 -
Extract all Title Sets from a TV Series DVD
By darinh in forum SVCD2DVD & VOB2MPGReplies: 18Last Post: 10th Sep 2010, 16:52 -
Picture sets to DVD
By Yaro in forum Authoring (DVD)Replies: 20Last Post: 5th Sep 2009, 08:33 -
Multiple VOB sets onto 1 DVD?
By bcemail in forum Authoring (DVD)Replies: 3Last Post: 6th Apr 2008, 17:09
