  1. Folks,
    i have apex dvd recorder 9000 power supply card is burned ( i can see burned diodes and few other components ) apex is giving hard time to sell the power supply card.
    card model number is DVDR-MKD1030511
    Now here is the question...which other model carry same power supply card??
    so i can buy that model and remove the card and reuse it.
    as some one told me cyber home 1500 is excetly same model as apex but i am in canada and none of the model are sold here.
    so before i buy cyber home i want to make sure that it has same power supply card.
    can some one please help me who has cyber home 1500 model to verify card then i will invest money.
    Thx for help in advance. Your help is highly apriciated.
    They are different.
    Find somebody skilled in electronics, have him/her make you a supply. If you do, let them know there's a market for it. One of my friends is looking into this himself, though I'm not sure how far he'll get.
    Nov 2003
    Mercer Island, WA
    Originally Posted by daffod
    Folks,
    i have apex dvd recorder 9000 power supply card is burned ( i can see burned diodes and few other components ) apex is giving hard time to sell the power supply card. .
    I think the other alternative is to sell your dead Apex on e-bay for $50-100 and use the money to buy a JVC or even a LiteOn 5001(called Daytek p-30 at Future Shop in Canada, it got a fan). All 3 recorder use same LSI Logic chip.
    Most of the recorder use standard DVD writer mechanism. If you take a look, yellow wire is for 12V, red wire for 5V and black for ground. It should not be too hard to modify a power supply for one recorder (or even a small PC power supply card) to another if physical size and shape is similar and power rating is good enough.
    Oct 2002
    Phoenix
    The power supply can be repaired and upgraded for $35.00 then the units are rock solid. I have two of them that work great after being repaired and having the firmware flashed to the latest version and a second fan installed inside to prevent overheating.
    http://www.drx9000repair.netfirms.com
