i got this cd image in bin cue, i used a virtual drive to load the image then copied the .mpg from the vcd image to my pc, now i want to convert the mpg to avi, but when i use vdub or tmpgenc, i get an error that says format is not supported, what other way can i change this from mpg to avi?
----> adamf9898 ---->
Why are you trying to convert the MPG to AVI? What are you wanting to do with the video... edit it or something like that?
If its a VCD it was a DAT file, it should be converted to mpeg with VCDGear, or extracted with isobuster. If its Mpeg2/SVCD you can frameserve it with dvd2avi before opening it in tmpgenc. VirtualdubMpeg2 can open mpeg2 files, its better than virtualdubmod in my opinion.
Edit: third time, now the vdubmpeg2 link MUST work? -
the reasons for converting it to avi is only because i can convert avi to vcd, and i just want all my movies to be ready as avi files
How to batch convert mpg to avi
By roberta in forum Newbie / General discussionsReplies: 3Last Post: 18th Apr 2011, 16:17 -
How Do I convert mpg or avi to vob?
By PHNeedsHelp in forum Authoring (DVD)Replies: 1Last Post: 9th Sep 2009, 13:29 -
Convert avi, mpg etc. to mkv?
By manutd in forum Video ConversionReplies: 9Last Post: 16th Aug 2008, 16:56 -
How to convert an mpg file to avi
By spyros in forum Newbie / General discussionsReplies: 1Last Post: 9th Apr 2008, 15:02 -
Need To Convert VOB 16:9 to 4:3 AVI or MPG
By hjordan in forum Video ConversionReplies: 1Last Post: 6th Oct 2007, 21:17
