I was just wondering if there are updates for existing programs, like Studio, or Ulead.
I just purchased a Camcorder, with Firewire and USB 2.0 jacks.
the included software ImageMixer, only captures video in VCD Quality.
I would like to be able to capture via USB 2.0 in DV quality, since i currently don't own a firewire card.
So far every other program I've tried only supports IEEE 1394.
Thank for any advice.
thats because dv avi can ONLY be captured with firewire. usb is not meant for dv capture. the usb port on your camcorder is for transferring still pics only. to transfer dv avi you MUST use firewire. is you have a desktop, you can get a firewire pci card for pretty cheap these days. if you have a laptop, they make pcmcia firewire cards that are also pretty cheap
Is there a proved working USB capture device with 3rd party software?
By ndep in forum Capturing and VCRReplies: 6Last Post: 18th Mar 2013, 02:55 -
USB Video Capture Software?
By ChibiBoi in forum Capturing and VCRReplies: 6Last Post: 20th Sep 2012, 04:07 -
Usb Capture Cards and Software Motion Detection
By glvid in forum Capturing and VCRReplies: 2Last Post: 6th Jan 2012, 09:44 -
Recomended Software for fast simple compatible capture and conversion
By The Turtle in forum Newbie / General discussionsReplies: 1Last Post: 28th Apr 2010, 16:10 -
DV to PC -- Firewire Problems; 1394 vs. USB; Capture Software
By GrayStrickland in forum Capturing and VCRReplies: 1Last Post: 27th Apr 2010, 12:27
