high guys
first off i read and followed the advice in common tmpgenc problems...
i tried to convert 4 movies and only one worked......i am using tmpgenc 2.59.47.155...
as with another try......while opening video source....i get an error saying exactly.....
"file XXXXXXX cannot open or is unsupported"
i am trying to open the mpg file from the mpg 2 folder...i also extracted the mpg from the bin and tried to open that.......same results
the advice i followed is
"Try first to change the directshow codec reader priority settings in TMPGEnc under Option->Environmental settings->VFAPI plug-in and right click on the DirectShow Multimedia File Reader and increase the priority to 2 or to the top of the plugin-list and try reopen the video.
If that does not help be sure that you have installed DivX or XviD or MPG2 or DV Codecs, read here how to identify what codecs you need."
i have the proper codec installed..i can watch the files on my media player
any suggestions?
looter
Results 1 to 9 of 9
Originally Posted by zootedlooter
open the file in virtual dub mpeg2 and then frameserve to tmpgenc.
Donadagohvi (Cherokee for "Until we meet again") -
read this link
https://www.videohelp.com/guides.php?link=99Donadagohvi (Cherokee for "Until we meet again") -
Look for the utility AuxSetup.exe in the VDub folder - double click it.
Click 'Install handler' - this will install the VDub frameserver.
Back in VDub load your MPEG, select the File menu and Start Frame server.
Click Start on the next prompt 'Framerserver setup'.
Save the frameserved AVI - ensure that you add the .vdr filetype!
You should(!) now be able to open the .vdr file that you've just saved with TMPGEnc - load it as the Video Source.
Remember that you need to keep VDub running until you've finished with the frameserver .vdr file.
Martin. -
thanx for all the help guys.......i tried everything but after following Abonds advice.i upgraded to a newer version and eliminated the problem
looter
.mpg won't open/burn correctly-help!
By keltoid in forum Video ConversionReplies: 6Last Post: 14th Dec 2009, 11:11 -
MPG Files taking a long time to open.
By Ads79 in forum Software PlayingReplies: 8Last Post: 13th Nov 2009, 09:39 -
VirtualDub can't open my mpg from camcorder
By ssalim in forum Video ConversionReplies: 3Last Post: 2nd Dec 2008, 16:46 -
Vegas Pro 8b Cannot Open MPG Files!! HELP :(
By 11233 in forum Newbie / General discussionsReplies: 3Last Post: 30th Jan 2008, 23:23 -
How to open and play a batch of mpg files in one go ?
By DBenz in forum Software PlayingReplies: 7Last Post: 2nd Sep 2007, 06:22
