Could anyone help me out with suggestions on a high quality brand of inkjet printable DVD+r blank discs. I currently use Verbatim and Maxwell regular unprintable discs because they work best with my Plexor 708 writer which is pretty fussy about what brand it likes. Any input would be most appreciated, also recommendations on where to buy the brands you recommend would be appreciated. Thank you.
Thank You,
GolfNut -
I use the BeAll 4x printable that are printable all the way to the hub - I've used hundreds and never had a problem with them (that wasn't my own, anyway)..... Normally get them through Meritline when they have 20% off BeAll sales....
Vidguy thanks for the reply. What kind of writer are you using? My Plex 708 is really picky about media brand and not sure if BeAll will work with it. Thanks again.
Thank You,
GolfNut -
I use a Sony DRU500A and also a LiteOn 411S. - BeAll is supposed to be one of the more compatible DVD-Rs, along with Ritek....
Vidguy thanks for the reply, I will give BeAll a try.
Thank You,
GolfNut -
I have good luck with supermedia
http://www.supermediastore.com/linkyo-4x-dvd-r-white-inkjet-printable-no-stack-ring.html
Printable BDR media recommendations?
By rysktkr in forum MediaReplies: 9Last Post: 2nd May 2011, 04:06 -
What printers print on Blu-ray inkjet printable media?
By videobread in forum MediaReplies: 4Last Post: 23rd Dec 2010, 18:08 -
Thermal or inkjet printable? How do I tell?
By bizzybody in forum Authoring (DVD)Replies: 0Last Post: 29th Apr 2010, 01:46 -
Need Advice on Labeling Inkjet Printable DVD
By mn072065 in forum MediaReplies: 5Last Post: 7th Nov 2008, 04:15 -
Taiyo Yuden 16X Water Shield White Inkjet Hub Printable DVD-R Media
By mn072065 in forum MediaReplies: 66Last Post: 28th Sep 2007, 10:29
