I have a new Nokia phone (6230) which is capable of playing video files in 3gp format.
usually, i am able to convert files from divx, xvid, mpeg etc using the nokia software supplied to 3gp, but the software does not recognise dvd's.
is there any software that can convert from DVD straight to 3gp (without first converting to divx)?
You can try converting the DVD to an uncompressed AVI file or use the HuffyUV codec which should give just as good quality but give you a file size that is at least half in size.Originally Posted by waheed
Shouldn't really loose any quality that way except such AVI files can be HUGE in size. Of course this is just a temp step but still you will need a rather large HDD.
When I convert a DVD to a 3gp it puts it into spanish
By ZQ8_Blazer in forum Newbie / General discussionsReplies: 2Last Post: 20th Jul 2008, 15:54 -
FFMPEG 3gp conversion
By diskontrol in forum Video ConversionReplies: 1Last Post: 19th Dec 2007, 03:50 -
3gp conversion problem
By nddcndndd in forum Portable VideoReplies: 5Last Post: 20th Oct 2007, 13:15 -
How to get subtitles using DVD Decrypter and either 3GP Converter or Nero?
By pjb_spammable in forum Newbie / General discussionsReplies: 0Last Post: 24th Jun 2007, 12:36 -
ffmpegx.... 3GP conversion= bad quality
By PIZZ in forum ffmpegX general discussionReplies: 1Last Post: 7th May 2007, 11:04
