Results 1 to 14 of 14
  1. I just bought a Panasonic DMR E50, and picked up some Maxells to go with it, just want to make sure they're OK.
  2. Member FulciLives's Avatar
    May 2003
    Pittsburgh, PA in the USA
    Maxell DVD-R discs are MADE IN JAPAN (even says so on the package) and as a result are one of the better DVD-R discs money can buy.
    Another good brand (perhaps even better if that is possible) is Taiyo Yuden. Sometimes Maxell uses Taiyo Yuden DVD-R discs if they can't keep up with demand.
    The last 10-pack of Maxell 4x DVD-R discs I bought at Wal-Mart had MEDIA CODE TYG01 which is Taiyo Yuden.
    The Maxell discs are fairly cheap at Walmart but you can get Taiyo Yuden even cheaper if you are willing to buy them on-line in bulk (when I say in bulk I mean in 50 or 100 packs).
    - John "FulciLives" Coleman
  3. Member 888888's Avatar
    Jan 2004
    Turdistan
    Maxells DVD+Rs are not made in Japan. The DVD-Rs are however. After a couple of time consuming headaches with cheap media, I bought a 50 pack of Maxell DVD-Rs from NewEgg and they are great! No coasters or other funny business yet. Good choice!
  4. Member glockjs's Avatar
    Feb 2004
    the freakin desert
    maxell 4x-R are the best you can buy off the store shelf
  5. Member FulciLives's Avatar
    May 2003
    Don't forget the FUJI 5-packs and 10-packs of DVD-R discs.
    These say MADE IN JAPAN and have always been Taiyo Yuden brand.
    But the MAXELL discs are cheaper than the FUJI discs.
  6. Excellent., thanks for all the input.
  7. What about the bulk Maxell -R you get from amazon or newegg (not those fake ones of course)? Are those from Japan too?
  8. Member 888888's Avatar
    Jan 2004
    Turdistan
    The DVD-Rs are. The DVD-Rs from NewEgg definetly all are.
  9. I have yet to hear of reports on fake 1-4x Maxell media. Maxell seems to sell only retail bulk in packs of 50, with the stock numbers of 635XXX. They are factory sealed spindles and are MXLRG02's (for now).
    Hopefully Maxell will continue this trend and only substitute TY's when volume becomes an issue. This makes Maxell dvd media a sure bet (which you can't say about any other major retailer).
    I have been very pleased across the board....silver matte printables, white matte printables, yellow tops and +R (Ricoh's). Consistent quality that's worth the extra few bucks.
  10. uh? not to be an ass, but seriously did you bother to do a search here first?
    maybe that' not obvious but it is best before wasting other's time take a few minutes of your own.
    I know you're new... that probably sounds harsh. sorry... just advice going forward.
  11. Originally Posted by Lobe
    Damn it, you made me waste time responding to your post!!!! Just kidding :P
    Blah, blah, blah
  12. Member 888888's Avatar
    Jan 2004
    Turdistan
    There is nothing wrong with asking people in the media section what they think of a particular DVD-R. The media reviews section is alright but there in nothing better than hearing present information from people who seem like they know what they are doing. For example, people often rave about Ritek media in the reviews but in the forums, people talk about these new bad batches. It was also because of the media forum that I decided to buy Maxell instead of Ritek, and I am very happy with my decision.
    Asking AFTER buying discs is a little weird though.
  13. it seems like it would be a bit pointless if eveyone started asking about what others thought... without first checking--not the media database but the forum! ,it would destroy this forum. I've been called on it myself I think.
    just look before you ask, no negative intentions implied, just trying to help him and all of us.
  14. Member 888888's Avatar
    Jan 2004
    Turdistan
    Lobe, I just noticed we have the interesting distinction of being two strange people who mostly post in the media section.
    All about 888888
    Member
    [0.05% of total / 2.71 posts per day]
    Find all posts by 888888
    Forums posts: Off topic: 203 posts / 49.03%
    Media: 151 posts / 36.47%
    DVD Writers: 14 posts / 3.38%
    DVD to DVDR: 14 posts / 3.38%
    All about Lobe
    Member
    [0.02% of total / 0.50 posts per day]
    Find all posts by Lobe
    Forums posts: Media: 137 posts / 93.84%
    Mac Video Forum: 9 posts / 6.16%
    Feedback: 1 posts / 0.68
    I also post a lot in the off topic forum but most of my meaningful posts are in media. My point is that somebody like you so commited to DVD media can't be too much off-track.
