Apologies in advance if the answer to this is already out there - I've been searching for days and I couldn't find it...
I d/l an .avi which has ac3 audio, so I demuxed the ac3 using Virtualdubmod and then encoded the video file using TMPGEnc. I authored the files back together with TMPGEnc DVD Author and burned them to disc however the audio is now @2 seconds ahead of the video.
I can play the original .avi using WMP on the PC and the audio is in sync. When I play the authored file on the PC the audio is out of sync, so the sync error seems to occur during the demux/encode/author process.
I also tried to encode the .avi as it is (and do without the 5.1 sound) and I tried saving the audio as a .wav file but these both produced a file with no audio at all.
Can anyone tell me how I can fix this?![]()
SYNC PROBLEM: X264 AC3/DTS MKV --->>> Xvid with VBR mp3?
By Randm in forum Video ConversionReplies: 6Last Post: 30th Jul 2013, 17:57 -
MKVMerge problem , audio out of sync - says This AC3 track contains 227 byt
By PSPGamer in forum DVD RippingReplies: 2Last Post: 20th Apr 2011, 16:38 -
AC3 Sync problem out of MKV file
By betão in forum Blu-ray RippingReplies: 7Last Post: 9th Jul 2010, 22:30 -
Odd ac3 sync problem
By mayancastle in forum DVD RippingReplies: 7Last Post: 24th Jun 2009, 21:34 -
Sync issues after converting AVI (DivX 5/AC3) to MPEG2/AC3
By Greycat in forum Video ConversionReplies: 4Last Post: 25th Mar 2008, 10:24
