I used DVDShrink to rip one of my movies, but I need a document or instructions on how to burn it onto a DVD-r or DVD+r disc using Roxio Easy CD & DVD Creator 6.
Thanks!
Latest version DVD Shrink can burn DVD+/-R. No need for Roxio!
Sam Ontario -
Yes
When setting the output format in DVD Shrink choose ISO image option that can be burned with DVD DecrypterYou stop me again whilst I'm walking and I'll cut your fv<king Jacob's off. -
Best to forget about Roxio. If you don't have Nero, the latest DVDShrink can be set to create an ISO image and automatically start DVDDecrypter to burn the ISO. The burn settings pop up after you hit the backup button in Shrink. Good luck.
Pull! Bang! Darn!
How do you burn initialized DVD discs?
By Djard in forum MediaReplies: 6Last Post: 24th Jul 2011, 13:26 -
Burn DVD and Blu Ray discs using Premeire Elements
By bornplaydie in forum Authoring (DVD)Replies: 0Last Post: 21st Feb 2008, 17:38 -
Can't burn DVD+R DL Discs
By RushMaster in forum DVD & Blu-ray WritersReplies: 7Last Post: 7th Nov 2007, 09:17 -
JVC SR-MV40 Video to DVD Instructions Wanted
By Trishymouse in forum Newbie / General discussionsReplies: 0Last Post: 11th Jul 2007, 13:10
