I was wondering if anyone could tell me why my mouse cursor with my Optical Mouse jiggles on my screen? This SUCKS when trying to draw a circle manually in Paint. What can I do?
Give it something to reference, instead of that glassy smooth desktop that you now use.
ICBM target coordinates:
26° 14' 10.16"N -- 80° 16' 0.91"W -
Uhm, I don't use a glassy smooth desktop. I use a book, lol.
A book may not have the best background. Use something with a speckled background, so the mouse can determine that it is moving. I had this problem with a pullout section of my desk. It has a glossy gray background. The mouse didn't know if it was coming or going. I finally bought some stick-on shelf lining paper with a mottled background and put this on my pullout. The mouse now works fine.
The only thing I would askis WHAT Optical mouse your using.
You see I have 2, one is a custom painted MS Intellasplorer or however you spell it. Its awsome, and I paid quite a bit for it.
The other is a $15 on specail MS Wireless Optical mouse, and its well... its ok -
i have two optical mice, a wired an wireless. the wireless is a jumpy mother ******, the wired is lovely. this is same brand and model etc.
If it's a USB mouse and you have several other USB devices it might cause this. Mine (Logitech wireless) does the opposite, it freezes while programs shut down or if one of the applications running in the taskbar kicks in. Usually a short duration 1-2 secs. Never had this problem when it was connected to the regular mouse input. I would chance it back, but I'm too lazy to deal with that 'wire snake-pit' behind my computer.
If it works, don't fix it.
Old XP Computer Boots to Black Screen and Blinking Cursor
By p_l in forum ComputerReplies: 57Last Post: 13th Apr 2012, 12:45 -
Mouse problem = looking for new mouse.
By Stealth3si in forum ComputerReplies: 14Last Post: 12th Nov 2011, 04:25 -
Saitek Notebook optical 800dpi Mouse!
By Soixante in forum ComputerReplies: 1Last Post: 13th Mar 2011, 15:09 -
No subtitles or menu cursor on my PC
By jonghyunchung in forum SubtitleReplies: 6Last Post: 8th Feb 2009, 05:21 -
Laptop cursor moves on its own
By dimtim in forum ComputerReplies: 8Last Post: 1st Oct 2007, 11:07
