Help!! Amateur needs help!
I'm trying to convert DVD back to MPEG/AVI to put foreign language subtitles and burn it back to DVD. I'm very amateur and have little ideas.
I currently have Vegas and also installed Womble Video Wizard. I want to keep the original quality without drop in its video quality.
Should I use DVD decrypter to convert to MPEG and bring the files in Womble and do the edit and burn it on DVD??
Doesn't quality drop when I decrypt and do the editing in Womble VIdeo Wizard?? How do I achieve above without drop in the video quality?
If I convert to AVI and edit in Vegas, would video quality drop further?
Honestly, I don't even know what's IFO, VOB, etc..
Please help!!!!!!!!!
Results 31 to 60 of 77
I tried using TmpgenDVD Author to re-author DVD images that were created by DivxtoDVD (TV shows). DivxtoDVD creates no menus and has chapter breaks every 10 minutes or so in the video.
Problem is when I select Add DVD Video just get an error message popping up with random characters in the message text. I think DivxtoDVD must be creating some strange format DVD video that DVD Author cannot handle.
Also tried to import the vob files into MPEG Wizard. That works okay and I can import two vobs that make up one video and join them and preview them but when I try export it says the video is empty
Have had some success using MPEG2VCR to open the vob file up and append the smaller second part of the vob file and then outputting a MPEG2 files
Larry -
Search for Batchdemux , its free and demux's both mpegs and vobs too elementary streams -
I have a dvd with subtitles but no menu and no chapters. I want to make a simple menu, and some chapters. This guide says nothing about subtitles. AFAIK TmpG DVD Author throws away the subs.
/jim -
Ulead DVD Workshop 2 is the DVD authoring program I use for subtitle support.
Hey there,
you also might find a very nice little tool helpful, called "VOB2MPEG", find it on this forum, this thread:
https://www.videohelp.com/forum/viewtopic.php?t=252033
Does exactly what it states, thanks to ChrissyBoy!
8) -
I have used DVDDecrypter, when the file is created, i try to edit it in TMPGEnc Mpeg Editor, i also tried to put it in TMPGEnc 3.0 XPRESS but both times the output file has no sound. so im really confused? any suggestions, email me..
This is what the generated text file reads:Originally Posted by jimmalenko
0x80 - Audio - AC3 / 2ch / 48kHz / DRC / LBA: 118 / PTS: 00:00:00.224 / Delay: -66ms
0xE0 - Video - MPEG-2 / 704x480 (NTSC) / 4:3 / LBA: 1 / PTS: 00:00:00.291 / Delay: 0ms -
Well, I read several reviews on the LG GSA-5163D so I bought one at Sam's
for $100 and have it hooked up on my computer via firewire (decided to go
external rather than internal).
I put in a DVD-RAM disc from my stand-alone Panasonic DMR-E80H and when I
click on the DVD_RTAV folder on the disc it tells me DVD_RTAV is not
accessible...access is denied. I want to get the files from the DVD-RAM
disc and convert to .MPG and edit.
Do I have a defective drive or is there something like "finalize" that I
need to do to the DVD-RAM disc?
I put in a DVD-RW disc that I had copied on my computer and it plays.
my audio is PCM as well. What program can I use to do this? Does both the video and audio have to be .wav or just the audio part? DVDDecrypter decrypted my video as .m2v and the audio is VTS_01_1 - 0xA0 - Audio - LPCM - 2ch - 48kHz - 16bit - DELAY 0ms. What does DELAY mean? Also how do I merge both the audio and video to make an .mpg. Very confused hereOriginally Posted by Baldrick
I've been transferring videos to DVD for sometime now and have had varied results.
I've got a MiniDV camera with DV (firewire) output.
Until recently, I've transferred from the tapes to the PC at DV quality (creating AVI files). I then use Roxio DVD creator to make MPG's and DVD's with titles, effects, edits,etc.
I recently bought a DVR with a DV input and went directly from the MiniDV tape to the DVD (creating .VOB files). The quality difference was remarkable.
I'm considering foregoing the titles and edits to retain the video quality (and live with the DVR's basic titling).
I tried converting the VOB files to MPeg (with DVD2MPG), but the resulting MPeg file looked no better than the MPeg created by going from tape to PC.
Is this a function of my software? my PC? my firewire card? the cost of encoding via PC?
I'm trying to figure our how to get my remaining tapes to DVD. I prefer nice menus and titles, but want the best quality video possible.
Any input you can provide is much appreciated.
Bitsurfer -
How do I combine all the clips in the video_ts folder using tmpgenc dvd author when re-authoring to mpeg-2?
Hello
I am making a dvd with Sony dvd architect 4
Is there a way to somehow use .dts files in dvd architect?
And maybe you know what to do with the problem about mv2 or mpeg files larger then 4070 mb for use in dvd architect(In Sony dvd architect 3 this was no problem!?)
Thx -
OK So apologies up front this is my first ever post so If i am in the wrong place or this question has been asked before SORRY:
I'm trying to convert Music DVDs into *.avi s so that I can ceate Video music playlists in WMP11. using DVD Decryptor and AVS Media I suceeded however I am coming across levellig problems due to the record levels on the original DVD. I was hoping using this guide, creating AC3 files I could use Cool Edit pro to adjust the levels of the audio to a consistent level and group the files back together then split as above. however for some reason when I open the AC3 file in Cool Edit pro all i get is static (ie hiss). this forum is my last resort - can any one either
A) suggest the 'proper' way to do what I am tryignto achieve or
B) help me resolve my static issues in Cool Edit pro
Thank you -
cool guide,very clever and simple to follow...bookmarked.
thanks so much!
I'm aware that this is an old post in an old thread, but does anyone have a current download URL for this tool ? The prior site in Italy ain't there no mo', and a Google search did not prove helpful. Or is this tool hopelessly outdated ?Originally Posted by pyscrow
Joining VOBs can cause problems. The easiest way to make one large VOB is to use DVD Decrypter. Set it to IFO mode, then under Tools/Settings/IFO Mode and set File Splitting to "None". One VOB, the convert to .mpg, or DIVX, or XVid using Womble if you want. No file joining hassles. Speedy too.Originally Posted by zakman
Please show me, what is the best software so that can convert to a mpeg file with the quality like the dvd? And why do some software work in VOB file, some software work in IFO file, so which one is better!? Please help me, thank you!
Dear friends,
I am not able to understand which version of tmpg enc dvd author you have used. kindly tell me the version in whcih i can find out the window for converting vob to mpg.
thanks -
What am I missing here? Why don't you just rip the DVD to the hard drive and change the file extension from .vob to .mpg? Am I misunderstanding the intent of this guide?
A VOB is not an MPG.Originally Posted by Captain Satellite
It can contain subtitles, multiple soundtracks, and is split into 1 GB chunks. While you might get away with treating like an MPEG in some cases, (small files, one soundtrack, no subtitles) in the general case it's not guaranteed to work. -
Thanks. It should work for the purpose of making a video compilation of various clips though, right? A short clip set to a song of special moments, about four minutes long.
Maybe. That's why I said "not guaranteed". In any case, the tools to do it properly are free and pretty fast (extracting is about as fast as copying), so why not try them?Originally Posted by Captain Satellite
You don't need any tools, I've already tried it. What's faster than typing three letters? Like I said, that must not have been the original intent of this thread. I say 'copy' so that you don't tamper with the original. I'm not telling, Alan, I'm asking. As far as I can see there is no need for a tool for what I want to do. Change the file extension then load that into my editing program. I'm not disagreeing with you, I believe we're talking about two different goals here.
How to convert DV avi files to DVD ready MPG files with Win7 powershell.
By findus in forum User guidesReplies: 5Last Post: 19th Dec 2011, 17:42 -
Can StaxRip Rip TV series DVDs or do I need to reauthor?
By nzdreamer55 in forum DVD RippingReplies: 8Last Post: 22nd Oct 2010, 11:18 -
How to convert DVD back to individual files
By mysts in forum Newbie / General discussionsReplies: 1Last Post: 19th Jul 2008, 08:19 -
Easy Freeware to make DVDs out of mpg and avi files?
By gail22 in forum Authoring (DVD)Replies: 13Last Post: 15th Oct 2007, 19:31 -
I want to reauthor DVDs without copying to the hard drive first.
By Big C in forum DVD RippingReplies: 2Last Post: 24th Jul 2007, 20:54
