i am really puzzled about this canopus pro encoder , i have used it quite a few times with no problems on projects on my xp pro os , but just lately it has started to crash the pc a few minutes into every task , i found some reference to this happening to other people and tried the compatibility mode idea but this made no difference to the crashes occuring , i also have enabled extra cooling , but perhaps the most worrying and puzzling aspect of these crashes is after reading the error report i saw reference to an error message that has plagued me a few times over the last couple of years and i cannot find any definitive solution to this error ( which i suspect is the cause of this problem ) the message i get is .
C:\DOCUME~1/EMO\LOCALS~1\TEMP\F836_APPCOMPAT.TXT
that last bit the appcompat.txt is the dreaded recurring and fatal error i have never found any once and for all answer to despite a lot of surfing and reading of similar reports , does anyone have a solution or a similar experience of this error please ?
Results 1 to 1 of 1
DVD FLICK, Start-up Error Msg-Unable to created txt file. Last DLL error: 5
By jacknscoob in forum Authoring (DVD)Replies: 5Last Post: 4th Mar 2012, 09:58 -
Problem capturing with canopus mpeg pro emr...
By dhugg in forum Capturing and VCRReplies: 4Last Post: 5th Jun 2010, 15:43 -
canopus advc 300 macbook pro
By petoo2 in forum Video ConversionReplies: 0Last Post: 9th Dec 2009, 20:29 -
Using Canopus ADVC110 to Export to VHS from Final Cut Pro
By richisgame in forum MacReplies: 4Last Post: 14th Sep 2007, 20:18 -
Canopus Pro Coder Problem
By Heineken77 in forum Authoring (DVD)Replies: 10Last Post: 17th Jun 2007, 05:15
