What is a program i can use to deinterlace my vob files that im converting to mpg for use on my comp? Im told that having interlaced video causes problems on progressive scan monitors (which i have). So to view them correctly on my pc i need to deinterlace. I tried TMPGEnc, but it created more problems deinterlacing then the ones already there
Results 1 to 30 of 30
ding, ding, ding - we have a winnerOriginally Posted by Abond
Buddha says that, while he may show you the way, only you can truly save yourself, proving once and for all that he's a lazy, fat bastard. -
You answered the question correctlyOriginally Posted by Abond
Not really but you could try ...Originally Posted by bubbamagic87
http://www.100fps.com/
I'm sure it will make sense to you all
http://www.digitalfaq.com/capture/interlace.htmOriginally Posted by bubbamagic87
http://www.100fps.comWant my help? Ask here! (not via PM!)
If software dvd players can deinterlace on the fly there must be a program that will deinterlace it for me with out looking bad (compared to watching it on a software dvd player).
If you don't see it at one of those two sites, the answer is "no" pretty much.
Is there a program that will open my mpg files in separate fields for use in virtualdub?
I know of Avisynth for avi files but i have vob or mpeg files. -
If it is MPEG-2 VOB or MPEG then you can run it through DVD2AVI to get a D2V project file which you can then load in AviSynth ... then open the AviSynth AVS script in VirtualDub.Originally Posted by bubbamagic87
But back to the original question I guess ... what format are you targeting? For instance DivX or Xvid or SVCD or DVD etc.
That does not work. You have NAV info, and possible multi-audio streams, subs, etc.Originally Posted by AbondWant my help? Ask here! (not via PM!)
I want to deinterlace because the only place im going to watch this is on my comp using some player like WMP or WinAMP. I want it to look just like it does when i play the dvd in PowerDVD. Is there a way to use the same deinterlacer as it does (unless there is a better one).Originally Posted by Abond
The 100fps site helped me out alot but the files they were deinterlacing were AVI and i have .vob or .mpg. So are there any tutorial out there that can help me with the mpg files or a program like AVIsynth but for mpg files that will allow me to open my videos different fields into VirtualDUB. -
Same rules apply, no matter file type.
Run the MPEG-2 or VOB files through DVD2AVI to get a D2V project file. This can now be loaded into an AviSynth script.
The AviSynth script can be loaded into VirtualDubMod and you can then do what they tell you to do at 100fps.com
Is it correct that de-interlacing a movie (film) DVD will have good results (since the original was "progressive") while de-interlacing TV series and the like will not succeed because the original is Video recorded (interlaced)?
All my attempts to de-interlace, back a year a go, have practically failed. Any de-interlaced video I've made play worse on the PC and is practicaly unviewable on TV.
What I have come to suspect is that if the video file is interlaced with Top Field first then s/w players play it fine. If it is bottom field first, then s/w players on the PC generate a combing effect (probably because they assume the file to be TTF).
Do you believe I am correct - or am I just saying nonsense?The more I learn, the more I come to realize how little it is I know. -
Maybe nonsense. The program does the same no matter what.
I said make a D2V project file not an AVI.Originally Posted by bubbamagic87
I mean you even quoted me so what gives!
Ok i got it into virtualDub and tried all the things it said to do in 100fps.com but i cant get rid of the bobbing. The only one that kinda workes is the field bob in virtualdub but that still has alittle bobbing when im done.
Is there a deinterlacer like the ones used in powerDVD?
The only thing i found to actually work is removing every other frame. -
Did you try Avisynth BOB() method?Originally Posted by bubbamagic87
Deinterlacing with TempGaussMC
By Gr0mk1 in forum Newbie / General discussionsReplies: 4Last Post: 21st Nov 2010, 02:41 -
A few deinterlacing questions...
By SBPP in forum Newbie / General discussionsReplies: 4Last Post: 17th Nov 2009, 00:42 -
What is going on with Deinterlacing?!?!
By jieve in forum DVD RippingReplies: 30Last Post: 9th Aug 2009, 16:23 -
OS X Deinterlacing
By ggp759 in forum MacReplies: 4Last Post: 22nd May 2008, 17:37 -
How to use the deinterlacing in the TV when using the TV out from the PC?
By erik1958 in forum Software PlayingReplies: 2Last Post: 9th Jul 2007, 15:07
