I have an anime film that I would like to put on a dvd, however, the film is in two parts (2 different avi files). They are both around 150mb and I would like to splice them together. I had been working with them in premiere and made it the way I wanted, but the end result was something like 2gb. The first part is encoded with DiVX 4 Fast and the second is recorded with Microsoft MPEG4 Video Codec-3. Does anyone know how I can restart this project with the right encoding and stuff so that the end file is around 300mb (should make sense, 150mb + 150mb == 300mb). Another problem is that that frame rate for both files is 20.00 fps (not an option in premiere when starting a new project). Premiere also doesn't list some of the a/v codecs i need to use. Has someone done similar and can help me?
BarfSnort
Geez, this is ugly...
A work around is right click over the clip in the timeline, and go to "interperate footage as", and type in the correct framerate..Another problem is that that frame rate for both files is 20.00 fps
When you create a Custom setting (ie Video for Windows), your codecs should be listed. If you know they're on your system for sure, and Premiere still doesn't detect it, then stay away altogether...Premiere also doesn't list some of the a/v codecs i need to use.
Save yourself some headache, and encode both movies separately, but tie them to play one after another through your authouring program. Just link them up..
Good luck!! -
Thanks alot. However, I want to use premiere to fix the two movies. They have some overlapping frames and I fixed it in premiere.
BarfSnort -
If you are wanting to put these two avi's on a dvd to play in a set top player then you are going to have to encode the two files to dvd compliant specs and they are going to be much larger than the original file size. Divx and mpeg4 have a greater compression than dvd mpeg.
For detailed guides on how to convert avi to dvd click this link.
https://www.videohelp.com/guides.php?tools=&madeby=&formatconversionselect=AVI+to+DVD&h...or+List+Guides
If all you want to do is put the two avi on dvd to watch on your computer only then burn that avi's as a data disc.
Good Luck!Donadagohvi (Cherokee for "Until we meet again")
Splicing WVC-1?
By Tim likes movies in forum EditingReplies: 2Last Post: 21st Feb 2011, 19:54 -
AviSynth Splicing Problems
By legocrazy1 in forum EditingReplies: 7Last Post: 14th Jul 2010, 00:15 -
splicing HD and SD formats together with AviSynth
By PapaDmitry in forum EditingReplies: 2Last Post: 5th Jul 2010, 06:25 -
AVISynth splicing many AVCHD clips - is it possible?
By Redrussky in forum Video ConversionReplies: 4Last Post: 4th May 2008, 19:18 -
tape splicing
By CogoSWSDS in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 9Last Post: 3rd Jan 2008, 08:44
