befopre converting my avi to mpeg i always use mp3 freeze to check for bad frames.(i use gary's avi to svcd 3 step foolproof guide).
occassionally mp3 freeze tells me there are no bad frames when there are bad frames because i get audio sync problems after conversion.
is there any way to find these bad frames besides checking every frame manually?
Not necessarily , it could be a screwed up file , or if it plays alright before encoding do you extract the audio from the avi and convert it to a .wav , and use the wav as you audio source.there are bad frames because i get audio sync problems after conversion.
Is the audio ac3 if so you should extract the ac3 file and encode only the video.
There are more causes of bad audio sync than just bad frames. If you scanned for bad frames and it said 'all frames appear good' then I don't know why they shouldn't be all good.
AC3 to MP3 in AVI via Virtual Dub
By Simmons in forum AudioReplies: 7Last Post: 22nd May 2012, 18:16 -
no mp3 options using v-dub
By DirtBikeMike in forum Newbie / General discussionsReplies: 2Last Post: 1st Feb 2010, 16:42 -
Virtual Dub Conversion Question
By zenzen1 in forum Video ConversionReplies: 14Last Post: 11th Apr 2009, 09:15 -
Tenders V-Dub MP3 Freeze VBR Audio and Bad Frames Guide
By tenders in forum User guidesReplies: 79Last Post: 15th Sep 2008, 21:34 -
Video Freeze after Conversion to NTSC
By gcam in forum Newbie / General discussionsReplies: 6Last Post: 1st May 2008, 10:57
