Running TMPGEnc version 12J only completes first file of multiple batch conversion.
I started with with typical AVI and did a "Add" to batch and save as MPG on 3 different movies. After first movie completed, TMPGEnc shut down and turned itself off. First move converted and completed just fine.
Did I do something wrong?
Are you sure TMPG shut down after the first conversion or do you believe it, because you saw only one mpg next morning? Make sure you gave each output file a different name, otherwise the previous one will get overwritten.
Just a guess. -
Thanks for the reply.
Yep, only the first one converted. Didn't over write anything. I tried this twice. Same thing happened each time. When I came back I noticed TMPGEnc wasn't running at all. Wasn't in the Task Manager either.
Tmpgenc Plus & TMPGEnc Batch List Creator help Please
By VOYAGER2009 in forum Video ConversionReplies: 2Last Post: 4th Jul 2010, 07:57 -
How to Batch Process Using Avidemux? Or Batch Processing H264 .m2ts or .ts?
By forgotpassword in forum Video ConversionReplies: 0Last Post: 14th Apr 2009, 00:00 -
How to batch encode with TMPGEnc
By BonnieW88 in forum Video ConversionReplies: 8Last Post: 20th Feb 2008, 20:52 -
TMPGEnc Plus won't complete batch jobs.
By Timex in forum Newbie / General discussionsReplies: 2Last Post: 6th Dec 2007, 23:13 -
Slight problem when hardsubbing in a batch
By bmwracer in forum Video ConversionReplies: 1Last Post: 25th Jun 2007, 17:32
