ok...i am converting Naruto to avi, all the other eps works, but eps 6, TMPGnc cant open it..(file name: [ANBU & AonE]Naruto - 06.avi), when i try to open it, it say unsupport type.. man.. what could be wrong?? its avi..
and oh yea in GSpot 2.21 this is the info
Video
Codec
4CC=MP43 ( all my other avi files say divx, but this one say MP43.. whats that??)
Name=S-Mpeg 4 version 3( all my other avi say DivX 3 Low-Motion)
hmm.. so can anyone help me out??
Try THIS tool .
Open your file and change the FourCC code to what the pic shows in the link (Div4 and Div3) all will become clear when you run the programme.
Then try it and hopefully you will be able to use the file.
If for any reason it doesn't work you can easily change it back to MP43.
Hope this helps. -
Try using smr patch codec for that,you can find it on google.com,divx headers wont work.
TmpgEnc Express can't open some AVI
By pcb in forum Video ConversionReplies: 7Last Post: 29th Jul 2011, 14:28 -
Can not open any file in TMPGEnc 4
By Soixante in forum Video ConversionReplies: 4Last Post: 8th Sep 2010, 09:56 -
can't open file in TMPGEnc
By windranger in forum Newbie / General discussionsReplies: 12Last Post: 18th Feb 2009, 10:25 -
TMPGenc DVD Author 3 will not open file from TMPGenc Xpress 4.0
By artyjeffrey in forum Authoring (DVD)Replies: 4Last Post: 8th Nov 2008, 14:23 -
Cannot open wav files in Tmpgenc
By deadlycow in forum Newbie / General discussionsReplies: 2Last Post: 23rd May 2007, 03:54
