have you good people had any success with DVD rippers when backing up any
DVD s that has good stereo options, Dts ,5.1 ? I tried with two different
types of software thus far,superdvd ripper and amigo,both have facilities
for copying in 5.1 stereo but when I replay my copies,avi files,they still play in
only two channel stereo?, my digital DVD player and Digital amp..system do
play all the stereo options that are available when playing DVD s,Dts,5.1
etc.,I hope you can help and thanks for reading this.
DVD Shrink will do this and it's free. The latest version not only allows you to select which audio streams to include, but you can also select which stream (5.1, DTS, etc.) will be the default. First, make sure you aren't simply failing to switch to the preferred audio stream (using your remote/set-top dvd player).
If God had intended us not to masturbate he would've made our arms shorter.
George Carlin -
I have used dvd decrypter to rip the whole dvd, and then crunch it with clonedvd and have had no problems keeping 5.1 or dts or both.
I'm not sure what you mean by playing avi files on your player.Dvd's are mpeg2,not avi.bmiller,ont.canada -
He want's AVI's with 5.1 sound.
That's easy, but you need avimux to put the audio and video back together.To Be, Or, Not To Be, That, Is The Gazorgan Plan
Preference for MP3 Joint Stereo Vs. Stereo ?
By davexnet in forum AudioReplies: 7Last Post: 27th Oct 2011, 12:49 -
Are there any tutorials to convert stereo MP3 to stereo AC3?
By rocky12 in forum AudioReplies: 10Last Post: 4th Sep 2011, 20:05 -
I keep losing stereo audio on my stereo bluetooth headphones (vista)
By yoda313 in forum ComputerReplies: 0Last Post: 30th Jan 2010, 10:19 -
Does anyone know how to convert joint stereo audio back to stereo?
By robrosen in forum AudioReplies: 1Last Post: 2nd Aug 2009, 23:24 -
Stereo, Joint Stereo or Dual Channel for Audio input type?
By c627627 in forum Capturing and VCRReplies: 1Last Post: 23rd Mar 2009, 10:33
