im kind of confused about resize methods. i have used percise bicubic .75 for all my encodes, but is that the right thing to use? when i cap i do it at 720x480, then resize to 352x240 for mpg1 vcd encoding,and apply other filters before that usually, then frameserv. i havent really been able to tell any difference between the modes but i want to do it the right way. i was also wondering what would be the right method for resizing a pal xsvcd mpg2 (converted to avi) from 720x576 down to 480x480 ntsc mpg2 or 352x240 ntsc mpg1. any help appreachiated.
<font size=-1>[ This Message was edited by: warbird on 2001-11-12 15:30:19 ]</font>
According to Jasc (of paint shop pro fame) Bilinear is for donwsizing, Bicubic is for upsizing. Bicubic will give you a sharper image, but it won't compress as well. Bilinear is also faster.
Ben Rudiak-Gould's explanation:
http://www.math.berkeley.edu/%7Ebenrg/avisynth-reference.html#BilinearResize
Megui Resize Filter
By xxxThiefxxx in forum Video ConversionReplies: 4Last Post: 19th Apr 2012, 00:00 -
resize filter in virtualdub for upsizing videos
By snafubaby in forum Newbie / General discussionsReplies: 1Last Post: 5th Dec 2011, 07:26 -
Resize filter in VirtualDubMod
By CSULB71 in forum Video ConversionReplies: 5Last Post: 28th Dec 2008, 12:48 -
How to use the Resize filter with WinAvi?
By GangstaRap in forum Video ConversionReplies: 1Last Post: 2nd Jul 2008, 06:28 -
Which one directshow filter to resize the image ?
By jazzzy in forum Software PlayingReplies: 1Last Post: 20th Feb 2008, 10:55
