Hi,
Since i've got my dvd burner, i like to make my videoss on dvd instead of svcd.
I capture some music videos and/or old video tapes at a resolution of 480 * 576 (I can't capture at higher resolution because the cpu isn't powerful enough and 352*576 is not good enough).
So I will resize my captures to 720 * 576 but i don't know with resize algorithtm is the best (bilinear, bicubic, lanczos).
Maybe a dvd authoring program will accept 480*576 (svcd) but it's not compliant so problems are expected with a standalone dvd player.
I'd like to resize and perform all video processing with avisynth (it's much faster than the resize / noise embedded in tmpgenc).
So what's the best resize method (bilinear, bicubic, lanczos) ???
I'm no expert but, i think its a matter of wether you want to enlarge or reduce the video size, I think enlarging from 480 to 720 horizontally, you may want to try Bilinear
I use Bicubic with 0,0.6. Have tried lanczos but didnt notice any difference. Read somewhere that lanczos can give sharper picture when upsizing, so maybe thats the best in your case.
I see you have a winTV go card. That card is based to bt8xx.
So, I suggest you to download and install the latest btwincap drivers. Then read this https://www.videohelp.com/forum/viewtopic.php?t=199669&highlight=
In short terms, you don't need to capture to 480 x 576. You can capture lower (368 x 576), then resize using lanzcos to 344 x 576 and pan to 352 x 576. That way, you gonna have a better picture than caping at 480 x 576, for the reasons anaylised on that post.
Direct capture at 352 x 576 is bad for bt8xx cards. Blury. There is a way to determine the sharpness of your card, but this works only on certain bt8xx variations (and not winTVgo)
help me how to make a set of avi files to DVD with menus of each avi file
By mmah in forum Video ConversionReplies: 5Last Post: 9th Mar 2011, 02:07 -
Risize 1080P to 720P with or without re-encoding best method
By onlyeuro in forum Newbie / General discussionsReplies: 3Last Post: 7th Jan 2011, 05:21 -
Found DVD/AVI software player that displays Chinese srt subtitles with avi
By jimdagys in forum Software PlayingReplies: 1Last Post: 14th Nov 2009, 19:45 -
Create Root menu for avi's on DVD without converting each avi?
By Ghtpua in forum Authoring (DVD)Replies: 2Last Post: 7th Sep 2007, 23:23 -
I have converted avi to vcd and svcd im looking to convert avi to dvd
By dbztoolkit in forum Newbie / General discussionsReplies: 1Last Post: 11th Jun 2007, 12:14
