Hello,
I have just encoded a moive to MPEG 2 ready for burning to a DVD
I am using TMPGEnc DVD Author to make the DVD.
When i select the video file i get this error,
How can i correct this ?
Do i have to encode the file again ?
Thanks![]()
gsvgaming.net sponsored by 4u-servers
You should have encoded to a DVD compatable format in the first place.
Encode the original file to DVD Mpeg2. -
as andyp mentioned, you'll need to reencode the file to DVD standards. Actually, it looks like you hit all of the errors. The ONLY other thing I could think of would be to try a patcher program and see if that fools TMPGENC DVD Author. To the best of my knowledge, I have never patched a SVCD and dumped it into TMPGENC DVD Author specifically, but you never know.
Best bet is to reencode the thing over. -
Will just encode it again.
I remember in the TMPGEnc it was set to encode to MPEG2, so it should be DVD standard.
I dint use the wizard, i just set the options manually.
Is there anyway to use the wizard put just encode the video ?
Thanksgsvgaming.net sponsored by 4u-servers -
Get Tmpgenc DVD Source Creator. It makes it really simple to get the files into the right format. You can get the free trial. I think it is also on sale right now since they are rolling out a new all-in-one product.
No, it doesn't do anything you can't do with Tmpgenc. It's just easier to use and understand for those who don't do this a lot. I really like to use it to convert a whole bunch of clips of different formats to the same format in one simple process.
TMPGEnc Dvd author 3 problem
By prcole18 in forum Authoring (DVD)Replies: 7Last Post: 7th Oct 2008, 11:33 -
BIG Problem TMPGENC Xpress V.4.4.1.237 + TMPGEnc DVD Author ver.3.1.2.176
By milindb1 in forum Authoring (DVD)Replies: 1Last Post: 20th Aug 2008, 02:41 -
menu problem in TMPGEnc DVD Author 3
By sanduul in forum Authoring (DVD)Replies: 13Last Post: 23rd Oct 2007, 19:20 -
TMPGEnc DVD Author 3 - Playback problem, Help!
By cbales_24 in forum Authoring (DVD)Replies: 2Last Post: 18th Oct 2007, 16:29 -
TMPGEnc DVD Author 3 (MENU PROBLEM)
By jaffacaique in forum Authoring (DVD)Replies: 9Last Post: 18th Sep 2007, 19:43
