Greetings my problems are the following one when I play the movies cvcd with cd rw used to play in my dvd coby 223 the image is bad and freeze and stop however with cd r I don't have that problem if somebody could tell me the possible causes.Thank you .
It may just be me, but I can't understand what you are asking.
which cd recommends me to burn the movies in format cvcd the CD RW or CD ROriginally Posted by Qm
If CD-R works, use it. It is cheaper than -RW anyway.
In other words,
CD-R es más barato que - RW. Utilícelo.
