Well i am working with a band to create a music video that they are going to sell. I've already figured out that a regular CD may not be able to hold what i want to do. So, i need to create the video and put it on a DVD. I am on a Mac computer with FCP HD. First, How should i export my finished video to keep the highest possible quality. Then, once my video is finished exporting, what program should i use to make a professional looking DVD? I'd like for it to have the menu's and everything else...Thanks in advance.
~ Nate ~
I think you'll get better answers in the Mac forum, so I'll move it there.
The Uncompressed 10-bit will probably keep the most video information, but if you plan on going to DVD anyway, MPEG-2 will make the most since.
DVD Studio Pro is the best DVD Authoring program hands down. It'll allow you to customize every aspect of your DVD. -
You should add a DVD-ROM section that has an HD (720p or 1080i) version of the music video, if your camera supports it. Adding that with DVDSP should be easy.
If it isn't broken, take it apart and find out why.
blog: deadsierra
create high quality dvd
By happyjays123 in forum Newbie / General discussionsReplies: 5Last Post: 11th Sep 2011, 21:12 -
high quality .mkv from DVD?
By avextraxjp in forum Newbie / General discussionsReplies: 3Last Post: 7th Mar 2010, 23:28 -
DVD to AVI (high quality)
By bob_smitty in forum Newbie / General discussionsReplies: 1Last Post: 4th Oct 2009, 09:39 -
&fmt=18 does not give the same quality as playing by "high quality
By arminio in forum Video Streaming DownloadingReplies: 2Last Post: 9th Feb 2009, 18:33 -
I need a high quality DVD Burner
By efb91 in forum Authoring (DVD)Replies: 4Last Post: 25th Sep 2007, 16:38
