When I burn a DVD with Sonc it usually resizes my mpg file so it won't fit on one disk. I am looking to get some better DVD authoring software anyway and was wondering if there is any software that will take the exact mpg2 file and put in on an authored DVD and thus fit all on 1 DVD. Thanks a bunch.
TMPGEnc DVD Author and IFOEdit (free) will create a DVD for you without re-encoding the .mpg file. If your .mpg file is too large (more than 4.4GB) to fit on one DVD-R, you can still create the DVD folder and then use DVD Shrink to make it fit.
Problem authoring mpg file with ffmpegx
By blue439 in forum ffmpegX general discussionReplies: 5Last Post: 14th Dec 2011, 14:23 -
anyone know of a dvd authoring program which can crop/resize?
By maca in forum Authoring (DVD)Replies: 7Last Post: 18th Jan 2010, 20:41 -
Why does this mpg file doesn't play sound in my divx player?
By Stealth3si in forum Newbie / General discussionsReplies: 15Last Post: 5th Jul 2009, 20:00 -
DVD Software that doesn't add black border
By Maikeru-sama in forum Video ConversionReplies: 8Last Post: 3rd Dec 2008, 14:08 -
software : pics to mpg file
By greendesert in forum Newbie / General discussionsReplies: 3Last Post: 21st May 2007, 00:04
